Quote: Is there a baffle under the pcv valve in the valve cover? They'll suck a lot of oil if there isn't one there. I'd personally toss the pcv valve and run another breather.
there is a baffle. there seemed to be a lot of oil on the outside of the neck that the pcv pushes down onto. was suspicious of that, which led me to check the inside of the hose and connection at the carb.
