That package I believe is from Best Machine. They have set up crate engines and rotating assemblies to sell thru Mancini. My
Is this true? If it is..I wouldnt think twice about having them balance it. Although $300 is on the high side for a nice balance job around here. You know it to Be right coming from those guys.
Can anyone confirm this?
I had a good chuckle out of the comment thad all those pistons were the same.. Other than CP Diamond pistons IMO were the best pistons out there...Although these Wiesco pistons for this Hemi was very, very close in weight. Right at a half gram.
I think that Eagle cranks and Scat even though are Off shore forgings are a little better than the no name stuff...I know they are tough from experiance. Im willing to bet that the Eagle crank, and rods I have run has over 1000+ runs on it.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
