Quote: I agree its not enough truck to load it to the hill, but my truck is rated for 8,100lbs and all Im sticking in the trailer is a 3,100lb duster, so Im ok.
not everybody can afford a special truck for everything or a biga**ed dually. Hell that 1500 is plenty good. we used to haul 2 1000 lb steers to market in 1/2 ton 48 Ford truck and spray feilds haulling 250 gallons of water around. 1.5 ton trucks were/are hauling 150 - 200 bushels of 60 lb/bu wheat to market. Cars were towing Air streams. People didn't have Sunday go to meeting trucks. You towed and worked with what you had. Some people still have to do that. PS: People towing trailers at 80 MPH shouldn't be towing. Just because the speed limit is 0/75 you don't have to drive that fast. Remember that you are towing and no matter what the load rating is you have to allow for it. Stopping distances and mauverability are greatly reduced with a trailer. 5 or ten MPH really don't amount to squat in a couple hundred mile trip. If you have to be some where that few minutes sooner - leave earlier. You will have a safer more comfortable ride and save gas to boot.
thats all fine and dandy, but if you get in an accident and somebody gets hurt because you are towing with the wrong vehicle prepare to loose eveything you own.
