Quote: Ray go make another test movie and tap the pump shot. have sombody look at the exhaust for smoke. and clean your garage while your at it.
but you are still dealing with 2 different circuits idle circuit tells you nothing about how it will affect the High circuit when the carb is wide open.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
