WHAT? I have had two of them in three different big blocks, and switched to belt drive because of the noice. In the engine dyno through mufflers the operator asked several times if the engine is really ok, are you sure that it won't blow up? Other than that it's a good unit, very reliable and accurate, easy to set on after you figure it out etc. However, nothing wrong with a good chain either, and a bunch less $.
I totally agree with this statement! We fired our 471 up and I thought the dyno was frigged up because of the different and very noticeable noise. I put my stethoscope all over the engine just to make sure and the second I touched the cover it just about tore my ear drums out. I think it does have a lot to do with the idler gear being and integral part of the cover. That being said- timing stays super accurate, once you know how to use the vernier type cam gear you can jack the cam around to whatever you want quickly and easily. My only piece of advice would be to get a GOOD dampener as I think it kicks the crap outta a lesser one pretty fast. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
