Will this run on the 91 octain I have available to me. If not what do I need to do to keep the quench but lower compression (if I have too)?
With those numbers I believe so and I'd make sure of all my measurements to get em exactly where I want them. If you go w full floating pins you can mock everything up, measure & easily pull the pistons to machine them for an exact zero deck height to go with your .039" gaskets. If needed you can enlarge/polish the chamber(s) with your porting burrs/tootsie rolls. Doesn't take much material to be removed.
