360 stock pistons
headers
airgap- carter 625 afb
I was running it at 35 but it was hard to start after it got hot. I set it back down to 30 and it starts alot better hot.
Where do yall run your timing?
so like 7.5-8.0:1 cr in that 360? run as much initial
as you can and limit the amount of mech. advance. mabey try 15-17deg initial and 20deg mech. should get you
where you need to be. that hot start prob could be many things not
related to timing.
Forgot to add it has a 480/480 lift 292/292 duration 230@.050 cam. I put a mopar thin head gasket. I must have atleast 8:1 CR
