Mine had no issues with the firewall or the trans tunnel and I run a JW ultra bell which is thicker than stock. My only reason was valve cover clearance on the passenger side, and I could not move it further due to one of the header tubes that kicks out under the frame rail to go around the torsion bar. It also helped the launch because the left front stays more even than it did in the past.
