Had a flex fan on my RR for 30 years with no problems, but I think the blades were steel with thicker steel plates sandwiching them to the hub with the rivets. Aluminum work hardens fast, so all that flexing can make the blades brittle.
On the other hand, I don't think I've ever seen a factory car with a flex fan, so maybe that says something also.
I've seen plenty of Aspens and Volares with factory flex fans...mostly 6 bangers with a/c....
