Re: engine guys, #3 bearing cap won't seat properly?
[Re: dvw]
#461811
09/07/09 01:55 PM
09/07/09 01:55 PM
Posts: 27,347 Today? Who Knows?
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Could the holes in the cap be so tight that the studs are causing the cap to lean over? I would try a stock set of bolts. If the stud to hole clearance was close and the hole bores were not machined square it could force the cap out of position. Doug
I agree, with studs sometimes you need to clearance the bolt holes to get the caps to seat properly & with #3 being the thrust bearing it's more critical...
Entire Thread
engine guys, #3 bearing cap won't seat ? **update**
gregsdart
09/07/09 05:36 PM
dvw
09/07/09 05:51 PM
1_WILD_RT
09/07/09 05:55 PM
RonP
09/07/09 05:58 PM
gregsdart
09/07/09 06:03 PM
RonP
09/07/09 06:12 PM
1_WILD_RT
09/07/09 06:16 PM
ccdave
09/08/09 02:25 AM
CompWedgeEngines
09/07/09 06:27 PM
gregsdart
09/07/09 07:29 PM
Cab_Burge
09/07/09 08:00 PM
emarine01
09/07/09 08:14 PM
gregsdart
09/07/09 08:20 PM
Ron Silva
09/07/09 08:38 PM
Hemiroid
09/07/09 08:42 PM
B G Racing
09/07/09 08:56 PM
gregsdart
09/07/09 09:17 PM
jamesc
09/07/09 11:51 PM
gregsdart
09/08/09 12:26 AM
Ron Silva
09/08/09 01:00 AM
jamesc
09/08/09 01:41 AM
dvw
09/08/09 01:47 AM
JohnRR
09/08/09 02:08 AM
gregsdart
09/08/09 04:18 AM
gregsdart
09/08/09 04:34 AM
Monte_Smith
09/08/09 05:07 AM
JohnRR
09/08/09 05:09 AM
Al_Alguire
09/08/09 05:14 AM
gregsdart
09/08/09 12:47 PM
The Shadow
09/08/09 12:55 PM
gregsdart
09/08/09 01:01 PM
The Shadow
09/08/09 01:21 PM
gregsdart
09/08/09 02:55 PM
Cab_Burge
09/08/09 04:19 PM
JohnRR
09/08/09 08:53 PM
602heavy
09/08/09 09:03 PM
Re: engine guys, #3 bearing cap **update**
gregsdart
09/08/09 09:33 PM
gregsdart
09/15/09 01:09 PM
S/ST 3040
09/09/09 12:57 AM
Moparnut426
09/08/09 12:16 AM
