Take this from someone who had the exact same issue. Make sure your fuel pressure from the back to the front is over 25 lbs. It cured mine instantly. Goes up and cuts out in the air. Went to the pump in the back and raised it to 28lbs. The regulator in the front was at 8.5 and I didn't change it but changed the one in the back. Problem solved. Hope it works for you.
