Best 60's ever all 1.28s. Got the bump stops set as tight as im gunna set them. Leaves the best around 2000rpm. Sounds like an feels like its starved for fuel right before 2nd an then after i shift it takes it a little time to recover.
I have video i will show as soon as the get it to me.
had the same problem today, my car was leaving hard and pulling up the frontend causing my jets to be uncovered causing a lean condition.
i raised my floats up on both carbs a bunch with a drill bit and problem solved. got my best et ever in bad air.
dont touch your fuel psi, thats not your problem.
