So am i actually adjusting this setup the WRONG way? I need to take the slack out ? So when i go full throttle it adds slack?
Sounds like you got the cable mounted wrong on the trans. As you open the throttle, the cable should be pulling the throttle shaft on the trans towards the rear of the trans.
Fastest 300
