This shows the correct orientation of the white & pink wires on the brake light switch. The wiring diagram isn't exactly clear which one goes where on the switch, but if you get them backwards your lights won't work right.
If I remember correctly, having them backwards makes your lights nice and bright most of the time, but they get dim when you step on the brake or flip on the turn signal.
