The blue fuel sending unit wire is routed incorrectly in this picture. When the trunk floor was replaced, the correct hole for the blue fuel sending unit wire was never cut out, so it was routed with the air shocks instead.
The holes the air shock lines go through are meant for access to the upper shock bolt. I've seen car with replaced trunk floor that didn't have this hole cut out. If your new trunk floor doesn't come with these holes cut out, make sure you cut them out or it will be very difficult to change your shocks in the future. These holes are supposed to be filled with a special body plug.
You can see the yellow and pink dome light connector in this pic. That is where the trunk light would plug in if you had one. This car didn't come with a trunk light originally, but it will have one when I'm done.
Tav
