Quote: Why not just cut the wiring on the current connector and put in your own connector if you have a connector for both sides of the wiring......
There isn't much of a pigtail to work with coming of the fan motor. I also have easy access to a yard with a bunch of chevys, so why not snip one. One thing for sure, I don't want to wire it up directly without a detachable plug.
