Because my rad was bigger than the fan/shroud and I had to offset it to the passenger side (to clear the water pump), I used the factory mounting locations on the driver's side, the one hole on the upper pass side and just drilled another hole in the lower pass side (as indicated by the red marks) and used those "push zip ties" for fans, etc.
