Quote: The latest Mopar Action has a 69 Coronet with 3.23 gears running low tens. The details on the engine are very thin, 512 cube stroker 400 with stage VI heads and a small roller cam with an operating range of 2k to 6k rpm. The builder states the biggest mistake most guys make is overcamming.
Can you guys with fast tall geared cars let the rest of us know some details of your cars?
Tim
I'd have to see a 3.23 geared car run low 10's to believe it. Unless the car has a ton of weight stripped off of it and running nitrous.
