Quote: "So the entire drivers side isnt working". Very odd, I'd recheck the fireing order and replace the cap/rotor. How much play is in the distrib? Points or Electronic ing? For an entire back to be out is strange. Is something shorted or not grounded? Did you check for spark buy removing each plug, grounding it and crank the engine a few times? you should se a sprk jump, if not the problem is electrical, if you have spark it'd be a fuel problem. Clean all the threads on the head real goooood install plugs back in and try it.
Distributer is 1 day old- Brand new electronic with HEI conversion inside. Cap and rotor are new. Yes spark jumps plugs when testing
