Quote: Junky WOT throttle shifts are controlled by the govenor weights in the back of the trans , but you give a perfect example of what J. Kunkel is talking about, people think it's working fine when it's really not, it won't fry the trans overnight.
Can you please point out where my setup is not working fine? So I get the explanation of WOT shifts incorrect and now I'm incompetent? And the Lokar kit isn't working correctly? There is nothing about my setup that suggests that it's not working properly. This is not based on what I THINK, it's based on my experience of the situation. Have you worked on or driven my Coronet? Perfect example, my foot. Enough said.
2010 Black Challenger SE <> 3.5 V6 Custom Shift Knobs www.flameball.com Check It Out
