Ran the car again last night.........
Made an easy check out pass and went 11.11 @ 127 spinnin the tires a little on launch because I didn't get a very good burnout.............
Next pass, I left a little harder (about 2,500RPM), but not hard enough because it bogged a little, and ran 10.97 @ 127............
I'd seen a local guy run 10.97 @ 127 in a supposedly 750HP small block in a 3,100LB S10, so I had him called out over the PA (this was his first time out with it)..........I launched a little higher (about 3,000RPM) and cut a .560 light to his .760 off the tranny brake and we both ran 10.69..........I went 127.6 to his 129..........
![](/ubbthreads/images/graemlins/drive.gif)
I ran a 1.53 to his 1.66 to the 60 foot mark........and I ran 6.82 @ 101.23 to his 6.90 @ 103 to the 1/8..........so, this is all he saw the whole way down the track.......
![](/ubbthreads/images/graemlins/biggrin.gif)
