Quote: not primer, dirty old black paint in need of some and east side of 75, stones throw from the Cadillac and Ford dealers. I dont think you mentioned rear springs. Super Stocks? I bet that thing will really work the suspention. Looking forward to seeing it run.
Doh........I don't know why I said 169........I knew 75 went through B-ville.....
Car's got some springs I had made at Tulsa Auto Spring.........They're REALLY stiff........The passenger side actually has a bit too much arch, so I'm going to have to pull it to have it dearched a little.........The way it is now, with the K-frame on top of a socket on top of my floor jack, the right rear is 1" higher at the wheel well, but I have to have the driver's side T-bar cranked all the way up to make it sit level, while the passenger side T-bar is level with the bottom of the control arm.......Just giving it half throttle, it pulls really hard to the left........so, it's obviously, got way too much preload........
