Re: Front end alignments at home, questions.
[Re: Challenger 1]
#348672
06/16/09 03:05 PM
06/16/09 03:05 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
I've got a caster/camber tool. It wasn't very expensive and my results have been pretty good. The only problem is that certain cars (FWD Mopars are especially difficult due to the adjustment effectively being inside the rim) are very difficult to adjust on a flat floor. There's just not enough room to get arms and tools around the tires.
Thanks for responding, is this worth owning? web page
I looked at that one...
It might work, but you have to put it on the wheel every time you make a measurement, each time it can be a bit different also, to make a reading you have to turn the screw until level, one more time consuming step when you have to make a lot of readings and adjustments (camber effects caster and vice versa); a direct reading scale is nicer...
Entire Thread
Challenger 1
06/16/09 10:55 AM
RapidRobert
06/16/09 12:01 PM
WILD BILL
06/16/09 12:25 PM
klunick
06/16/09 12:45 PM
Gusteve
06/16/09 01:05 PM
pushbutton
06/16/09 01:19 PM
Challenger 1
06/16/09 02:18 PM
Jim_Lusk
06/16/09 02:31 PM
Challenger 1
06/16/09 02:57 PM
6T6Cuda
06/16/09 07:05 PM
Colin Frolick
06/16/09 03:00 PM
WILD BILL
06/16/09 03:20 PM
Challenger 1
06/16/09 05:15 PM
DJVCuda
06/16/09 05:45 PM
WILD BILL
06/16/09 06:29 PM
6T6Cuda
06/16/09 09:03 PM
Challenger 1
06/16/09 11:13 PM
WILD BILL
06/17/09 01:51 AM
mkdart
06/17/09 03:02 PM
WILD BILL
06/17/09 03:12 PM
mkdart
06/17/09 04:33 PM
WILD BILL
06/17/09 05:38 PM
6T6Cuda
06/16/09 07:03 PM
