Quote: I got a set of Jesel pushrods today.... Only problem with them is that they cost $42.75 each or $684 per set!
Is the roller cam you plan on putting in so radical it can't use thick wall 3/8" pushrods?
The last test with the Comp MM305S flat tappet cam was thousands of dollars cheaper. It will be interesting how much more power the Jessel setup and roller cam makes on the dyno.
