The governor weight is comprised of three major parts, the outer weight, the inner weight and the spring.
The outer weight has most effect on part throttle upshift speeds while the spring has most effect on the WOT upshift speeds. The inner weight affects both part and WOT shift speeds.
With a severely lightened inner weight and a light enough spring it's possible to configure the governor to where the upshift rpm's exceed a particular engine's capabilities.
The INTERNET, the MISinformation superhighway
