I put my outer weight in a lathe and grooved the center @ 1/8" off diameter 1/2" long to bring up 1-2 shift and drilled the center of inner weight 3/8 diameter @ 5/8 deep to up 2-3 shift. Theres also a spring. I found a few lighter ones and tried and worked out a combo I liked.
