Not sure on the 89 truck A833 setup, but the 89 truck NP435 setup teh bellhousing is for the big 143 tooth flywheel and is cast iron, monsterously huge and not a good fit for the A body.
You know, I can't remember if the bellhousing was aluminum or cast iron. I "think" it was aluminum. But it was rather bulky and set up for the large flywheel.
Stan
