Quote: I built one last summer.Used the stock cast pistons I have hit it with a 200 shot for a year now.
Mopar cast pistons are actually very stout. I would like to use the later 75 & up 400 cast piston w a 440 crank if the dimentions would make for good quench but I believe that it would need valve notches to be cut.
