Originally Posted by 1980volare
Originally Posted by racerx
What are the final #'s
4.96 142
Currently at 3610lb race weight; I took the glass rear bumper off and put the steel back on so it’s about 60lb heavier. Stock 5.7 block, stock 6.4 heads with comp springs, good crank rods and piston. 1.80 glide. And two $800 turbos. Uncle Rico’s Dana 60 out of a van cut down with some caltracs. Stock goofy transverse torsion bars with Viking DA shocks.
Might try and get out one more time this year and go a little faster.
That's pretty incredible!
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
