You racing no prep ? Try some radials and get on a prep surface , instant 4’s . Otherwise if you going in the 4’s with 1.20 60 foots , you making some power out the back !
Radials and normal weekly test and tune prep, so it’s basically no prep.
Radials with out decent prep , with a car like yours not going To work well . Get on a radial prep track and you will run well . Otherwise you compromise your potential.
