Although the engine bay cleaned up fairly nice, the driver's side inner fender had a lot of surface rust and some rust around the fender tag and under the battery tray. I briefly thought about just having the driver side inner fender painted but knew the colors wouldn't match so I figured now is the time to just do it once and do it right...I pulled everything out of the engine bay and hauled the charger over to my sheetmetal/paint guy. I had him delete the battery tray shelf since the battery will be in the trunk.
