I've been putting off removing the undercoating from the rear wheel tubs because its such a nasty job but I finally started in on it yesterday. Small areas of the undercoating had fallen out over the years. This way I can seal and undercoat everything from the firewall back.
I used a $30 ebay needle scaler and if you haven't used one to remove undercoating, you really need to. It FLIES off....which is why its so messy!
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
