Originally Posted by Craig J
Originally Posted by dvw
If you are reusing your current brakes? The parts won't bolt on with different bolt pattren ends.
Doug
It seems like Strange made the effort to make the bigger bearing work with the mopar brakes.
Did not know that , seems like a no brainer then to go with the bigger bearing
Mainstream Media is the new Pravda
