Originally Posted by Craig J
Originally Posted by JohnRR
Are you going to run green type bearings or use the stock tapered bearing ?
Ball bearing, I am not sure if it is mfg by Green.
Green is a generic term at this point , just run the stock mopar bearing size , as other said , your factory brakes aren't going to fit , if you are going aftermarket rear disc then you have a better chance of getting something like TBM because they don't make parts for the musclecar era mopars that I have been able to find
running up my post count some more .
