Hughes Engines website has a really good few pages of cam and lifter installations, decreeing cams and such, use to think it was overkill but I ran a lot of his cams and never ever had any problems when using his instructions. These were all pretty aggressive cams and edm solid lifters. He was a big preacher of spinning the cam with a ratchet and making dang sure all the lifters turned. Very good articles, his oiling system instructions were a mere couple of paragraphs not in the oiling systems article but in the stroker assembly article iirc.
All flat tappet lifters ‘roll’ around the cam, do it slide. Cam turns on outside of lifter not center.
