VR-1 here. my machinist has lost a few motors on the dyno. he uses the penn oil. he is quite leery of current flat tappet offerings. When doing a stock rebuild he has someone grind the cams with added taper on the lobes to aid the spinning of the lifter (might be howard's). Anything aftermarket is typically roller. twocents
