I was really just joking about not being allowed to hangout on this sub-forum……ya ain’t getting rid of me that easy LOL. I do appreciate the kind words though.
Dart4forte, I’m not sure how comfortable you are with rebuilding a carburetor, but the Rochester 2Gs are about the simplest ones to go thru. You’d asked about a complete kit and I came across this one today.
s-l960 by
M Patterson, on Flickr
It’s sold by speedway thru their E bay store. Type in “Universal Rochester 2-Jet 2G Tri-Power 3x2 Carb Kit” on E Bay. Don’t know if there is any price difference between E Bay or their store so I’d check both places. They sell it with and without linkage. The kits are about 450 and 350 respectively. This kit includes the correct base plates for the end carbs and the shafts are extended to move the progressive linkage to the passenger side, along with an extended shaft for the center carb. You still have to provide the 3 rebuildable carbs.
Since almost all of the old mom and pop junk yards are long gone, there are only about 3 sources left for carburetors. The easiest and most expensive would be to order 3 rebuilt carburetors. You can always go E Bay shopping but my experience is the 2Gs you find there are usually way over priced. My favorite source was the swap meets. You always run into the guy who thinks every junk 2G is a tri-power carb and will try to get $50 and up for them…..in most cases you can find the guy who is just trying to clean their shelf off and are a lot more reasonable. Back when I was setting up tri-powers (and the 6X2 on the 37 Dodge) I’d snatch every small base 2G I could find that was $10 or under, and there were a lot of them.
The nice thing about the 2Gs (both large and small base) is now days it’s pretty easy to find the original application for the Carb. Unless it’s a really early carb with a metal number tag, the carburetor number is stamped on the passenger side of the fuel bowl. You can see the numbers on the picture of the Chevy tri-power that shows the fuel lines. Type number into a search engine and usually one of the first results will be the application (division, year and engine displacement).
Most of the Rochester small base carbs you come across will probably be Chevrolet. In most cases the choke on these will be external (a heat stove cast into the intake with a rod running up to the choke plate). These work great for the end carbs but can be problematic to get an automatic choke on. If you’re real lucky you may come across one of these. They were normally found on Pontiac and Oldsmobiles (and even a few Jeeps). On the small base carbs equipped with integral choke they are normally mounted on the top cover (unlike the large base carbs where the choke is normally mounted on the base). Don’t worry if the choke isn’t electric, all it takes to convert it is the correct electric choke which can be bought separately (which I did on the 2 tri-powers shown below).
SB EC by
Personally I prefer to run my linkage on the drivers side, that way I don’t have to worry about building it around the fuel lines or choke but that’s me. As I mentioned the linkage on my HEMI tri-power is based on the 60s Ford tri-power. The front slide pulls front carb open and the real slide pulls the back carb open.
The turnbuckles came from the local hardware store and the ends were just flat stock with a slot cut and welded to the threaded end of the turnbuckles.
AC 1 by
This is my Small block Chevy tri-power that I’ve run on several engines, from 283 to 383 stroker (I also converted it a large base center carb way back when it was on the 383). I took a different approach for the progressive linkage on this one.
2 by
You’ll notice the linkage is mounted high up on the center carb and low on the outboards. This causes the outboard carbs to open quicker and ideally all three carbs reach wide open throttle t the same time. The linkage is completely adjustable so that both end carbs start opening at the same time.
On the Chevy setup the top rod is adjustable to set the tip-in point on the end carbs. The bottom rod is adjustable so that it can be set to drop in the holes when both carbs are closed (too short or long and one or both of the carbs will be slightly open at idle). I could have made it non –adjustable but I found that if the end carbs are removed and put back on there is just enough slop in the carb mounting hole that they might shift from where they had previously been and the rod will need to be adjusted slightly. This linkage was just build out of some old linkage pieces I had laying around and an eye bolt from the hardware store that was the right size for the top rod to slide thru.
For fuel lines the simplest is probably just a fuel block and lengths of fuel line. If you’re trying to replicate an engine built in the 50s this is probably the way to go and they look kind of neat looking with the colored translucent fuel line that was popular back then. One caution on the clear or colored lines though…..most are not rated for ethanol fuel (E10/E15). You can swear up and down you’ll never run anything but not ethanol gas in it, but what are you going to do if our on empty and ethanol is all the station has. The picture was taken the day I swapped over to dual quads so the intake was pretty nasty after a decade of being on the car.
T2 by
Personally I do prefer hard-lines, they’re simple to make if you have a good tubing bender and double flare kit. The tubing and fittings are pretty inexpensive. A variety of fuel blocks can be found on E Bay and the price isn’t usually too bad.
T1 by
Or you could go the route that Mopar took with dual quads (and as I recall the six pack setup)……a hand full of brass fittings and some pieces of tubing.
3 by
You might notice on both setups that between the fuel lines and electric choke it would start getting real crowded on that side if you add the progressive linkage.
A quick word on carburetor kits. I’d stay away from the cheap Amazon rebuild kits. They are absolute junk. Spend the extra money for a good kit from NAPA or similar.
Doing your own work on the carburetors bases, building your own fuel lines and linkage you could probably set up a set of tri-power carbs for under $500. That would include the core carbs, rebuild kits, air cleaner(s) and electric choke.
Anyway this was just a few more thoughts.
