Originally Posted by volaredon
Ok thanks. How bout the dummy shaft used to measure off of that goes in place of the output shaft
I’ll have to see if I have one of those. Unless you change some hard parts you can reuse the shim at the back of the intermediate shaft.
In other words, a re-clutch won’t requite a new shim.
Make sure when you do the trans build the OD assy, install it then build the remainder of the trans and check input shaft end play last.
