If the engine you’re considering this on is up and running, and you want to get a feel for how it will behave with Hyd lifters in it…… just set the lash with the solid lifters to nearly zero, and see how you like it.
With the Hyd lifters, properly adjusted, it will be zero lash.
This lets you experience it without swapping the parts.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
