also solids have a lash take up ramp that would cause the hydro lifter to not work properly , solid on hydro cam is fine if run very tight
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
