Originally Posted by Brad_Haak
Sound rights; measures 214 / 226 @ .050", 115 LSA. When you install it, you may find it's already advanced 3 degrees when put "dot to dot"... at least the original one I checked from a '69-1/2 440 6-BBL car was.
it wouldn't surprise me one bit that the 1969 1/2 six barrel motors did not have the same cam, grind and vendor as the 375 HP single bolt 440 motors had work shruggy
I believe those were the first 440 HP motors to get the three bolt cams and timing sets shruggy
