Put it in some V blocks(wood, steel or whatever you can use) and measure the lobe lift with a dial indicator or measure the flank of both an intake and exhaust lobe and then measure the lobe height off of the bottom of the lobe to the top of the lobes with a set of dial calipers then due math the wrench scope up
