Of the three at the link I would go with the trans eagle. I have been selling them for several years now to my local construction and lawncare customers with trailers. No issues to report. I consider them a good "budget " friendly trailer tire.
If you wanted a step up without spending goodyear money consider the Hercules strong gaurd st if there is a Hercules dealer in your area.
In your size an 8 ply is sufficient most of the time. If you need a 10 ply in this size you are probably at or over the limit of your trailer.A step up to 225/75r15 will carry more weight if you have the clearance.
