Re: modern alternator swaps for BB, highest amp at idle?
[Re: Blown71X]
#32041
11/20/06 04:22 PM
11/20/06 04:22 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
Feets If I remember right there is a application for the same year caddy with a different engine that has the same case clocking with a serpentine pulley, tho I don`t remember how many ribs.
edit: I`ll add this to....if you are running EFI with a OE chrysler alternator and you think it is ok, Go take a look at your Gross Voltage correction (if you have this ability)while at idle and cruise, you won`t like what you see.
exactly what is driving this post.
Is that a CS-130 alternator?
In the wiring diagram, that assumes a 1 field application, correct? I upgraded to the 2 field with the solid state regulator, so what do I do with the other field wire?
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
Entire Thread
modern alt. swaps for BB, highest idle amps? update
whiplash
11/19/06 09:33 PM
dave571
11/19/06 10:41 PM
Jerry
11/19/06 10:54 PM
11/19/06 11:19 PM
whiplash
11/20/06 02:08 AM
Blackwidow69
11/20/06 02:37 AM
Jerry
11/20/06 03:20 AM
whiplash
11/20/06 12:38 PM
Jerry
11/20/06 12:46 PM
Blown71X
11/20/06 03:03 PM
whiplash
11/20/06 04:00 PM
Jerry
11/20/06 04:32 PM
whiplash
11/20/06 04:41 PM
Blown71X
11/20/06 05:34 PM
whiplash
11/20/06 08:22 PM
Blown71X
11/20/06 09:30 PM
whiplash
11/21/06 02:06 AM
challengermike
11/21/06 04:15 AM
Blown71X
11/21/06 02:44 PM
defiance
11/21/06 03:32 PM
Dragula
11/21/06 07:32 PM
challengermike
11/21/06 11:03 PM
JeffC
11/22/06 06:00 PM
Clair
11/22/06 06:16 PM
Blown71X
11/22/06 06:18 PM
70blackfish
11/22/06 07:32 PM
Blown71X
11/22/06 09:07 PM
Dakota_Don
11/23/06 02:05 AM
Blown71X
11/23/06 02:42 AM
Dakota_Don
11/23/06 03:44 AM
whiplash
11/24/06 02:55 PM
whiplash
11/24/06 03:16 PM
Von
11/24/06 04:31 PM
whiplash
11/24/06 04:46 PM
Verga
11/24/06 04:50 PM
dbdartman
11/24/06 05:06 PM
Dakota_Don
11/27/06 02:44 PM
whiplash
11/27/06 07:33 PM
whiplash
11/30/06 02:17 AM
whiplash
11/30/06 02:43 AM
Von
11/30/06 03:15 AM
whiplash
11/30/06 12:13 PM
Von
12/01/06 02:19 AM
Blown71X
12/01/06 01:53 AM
Pool Fixer
12/02/06 01:14 AM
Von
12/02/06 07:47 AM
whiplash
12/02/06 01:26 PM
Von
12/02/06 05:02 PM
whiplash
11/20/06 12:36 PM
AndyF
11/20/06 06:27 PM
AndyF
11/20/06 06:30 PM
moparpollack
11/21/06 04:28 AM
AndyF
11/21/06 05:39 AM
65rbdodge
11/21/06 01:28 PM
feets
11/21/06 07:30 PM
whiplash
11/21/06 11:19 PM
Blown71X
11/22/06 02:07 AM
challengermike
11/22/06 02:21 AM
Skeptic
11/22/06 02:49 AM
Von
11/22/06 05:28 AM
70blackfish
11/22/06 05:44 AM
whiplash
11/22/06 12:26 PM
whiplash
11/22/06 01:39 PM
70blackfish
11/22/06 04:18 PM
Verga
11/22/06 04:49 PM
Skeptic
11/22/06 02:35 PM
Skeptic
11/22/06 03:05 PM
Re: modern alternator swaps for BB, highest amp at idle? *DELETED*
Verga
11/22/06 03:27 PM
whiplash
11/22/06 04:23 PM
Verga
11/22/06 04:38 PM
70blackfish
11/22/06 04:45 PM
Jerry
11/22/06 04:50 PM
CrAzYMoPaRGuY
11/30/06 03:44 PM
whiplash
11/30/06 05:36 PM
whiplash
12/01/06 03:33 AM
70blackfish
12/01/06 03:51 AM
whiplash
12/01/06 04:03 AM
whiplash
12/01/06 01:18 PM
Von
12/01/06 05:16 PM
whiplash
12/01/06 06:39 PM
Von
12/01/06 07:53 PM
whiplash
12/01/06 08:51 PM
jeepers007
12/01/06 09:47 PM
VZCharger
12/01/06 11:48 PM
Von
12/02/06 12:57 AM
Blown71X
12/01/06 03:56 AM
