Yes, if you are going to be reusing parts then the build goes down a different path. Sounds like the short block will be all new parts though?
Yes, I would be starting from scratch on the short block unless I stumble onto a good deal used. I do like the idea of going bigger with the engine and being easier on parts. Lower RPM etc. I race a lot and longevity is a requirement.
