It sure seems like at this point, the logical step forward would be to get the wiring done. Then see if the last round of the changes you made yielded the desired results.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
