Sounds like you're on the right track. Just get some measurements from the stock intake before you shop intakes and make sure the new one will work with the air grabber. The 440 Source heads should be good and they offer a good range of cams. His goals are easily obtainable. Enjoy the build.
2011 Drag Pak Challenger
