Enter the VIN here to see if it's been reported stolen or salvaged.
https://www.nicb.org/vincheck
Depending on the state you're in, tow companies usually have a process to tow it, put a lien on it, then sell it at auction. The paperwork you get from the auction can then be used to get a title. The tow company might not actually "tow" or "auction" it either. wink
Best is if the seller can get a title. Otherwise it had better be cheap.
edit: The Vermont loophole has now been closed, so that won't work.
If you ever find yourself in a fair fight, your tactics suck.
