No farther than you are going you could spend some money on the 318 or swap in a 360, Unless hills are involved. A 408 Stroker would give you big block torque in a small block package provided the heads could move enough air.
A 360 magnum with hyd roller cam would likely do just fine for a lot less money.
I love my big blocks but don't look forward to that much work any longer.
