According to the info below the E body axle is only just over 1 1/4" narrower than the '71 and newer B body one. If you could find a pre '71 B body axle you would be almost 3" narrower.
That shows all 62-70 B body 8-3/4 rears as the same width. Aren't 65-67 narrower?
i'm almost positive the 65-66 rears are an inch or so narrower than the 68-70 rears.
i know for a fact the 66 rear i installed in my 64 belvedere post car was an inch plus narrower on each side than the original keyed axle rear was. also, i believe the 64 rear is wider than the 62/63 rears, but i don't know by how much.
that chart has been around for years, and has been complained about being wrong for as many years as it has been out there.
